Hi, I have a new secondary system, this one is the Growatt 3.6 Hybrid inverter, & at first I had, 2 AXE 5kw batteries.
We use 24/7 nearly constant 1 kwh.
The week after, liked it so much, purchased another, AXE 5kw battery, I simply shut everything down, pulled off the safety connection bungs on the new AXE battery, pulled off the power cable lead socket from the top battery, planted the new AXE battery onto the top of the existing AXE battery's & plugged onto the top, the power cable. Powered inverter up, turned solar array on, a few minutes later Inverter said OK, & I pressed on the battery red power buttons. DONE. You could time taken to a few minutes. Just like stacking Lego bricks.
"Albeit making sure it was all powered down first". If available, we should have bought these years ago.
My only gripe with the inverter, I wish it had a separate percentage, power left display.
On the inverter you have to scroll through the LED display, to show percentage of charge , but on the mobile app, that is instant.
The inverter also has an emergency power output, easy to enable & disable.
I connected mine to a protected 13a socket, & from there, I can run cables as need, so long as they DO NOT join anything into the mains.
