Hi. We have 10 x 405W panels, a Growatt SPH3600 inverter and Growatt 5 kW battery (AXE 5.0L-C1 5kW). We are currently on the Flexible Octopus (Import) and Outgoing Octopus (Export) tariffs, but are thinking of switching to Flux to make use of the cheap Flux rate at 2-5am.
So I recently changed the "Battery First" settings to force charge the battery between 2 and 5 am (cheap flux rate period @ 16.13p/kWh) as a test to see how long it took the charge the battery from 11% to 100% and then how long the battery lasts during the day while we are at work. The reason is to see if there would be enough kW left in the battery to get us through the peak Flux period (4-7pm) as we do not want to have to import during this period (37.64p/kWh instead of standard 26.88p/kWh) - that would negate the point of moving to flux. As part of this I was also wondering if a second 5 kW battery would be a worthwhile investment (our battery is already 6 months old so need to make a decision as cannot mix and match new with old according to Growatt manual).
The AXE 5.0L-C1 has a nominal voltage of 51.2V, max charging curent of 60A and max charge/discharge of 3 kW. So on this basis I expected the battery roughly to be charged from 11% (0.55 kW)) to 100% (5 kW) in approx 1.5 hrs (ie 5-0.55/3). But it actually took the full 3 hrs to charge the battery. Obviously I forgot to factor in the load drawn by the house, which for that period was about 0.2-0.47 kW, but even factoring that in it seems to have taken a lot longer to charge the battery than expected. Am I thinking about this wrong?
The discharge numbers (to the house only) were as follows:
2am - 11%
5am - 99%
6am - 94%
7am - 80.6%
8am - 75%
9am - 67%
10am - 61.2%
11am - 54.8%
On this particular day we had very little solar energy produced. As it was November we had only around 7 hrs of daylight, The day load stayed pretty constant between 0.2-0.5 kW. So left wondering if we moved to Flux there would have been no energy left in the battery by the time we got to the 4-7pm Peak Flux period. So then we would be Importing at a high rate just as we return home from work. Not what we want. In this case then a second battery might be worthwile to get us through that period even if we have to charge at the Standard Day rate (same rate as we pay on the Flexible tariff so no big deal to do this). Then of course we also need to factor in the cost of the baterries and their life-span!
This is really hurting my head trying to work out what is the best thing to do. Can anyone recommend the best settings so that we dont Import from the grid during the Peak Flux period? Should I just tell the system to keep the battery charged for much longer than the 3 hr Flux Period so that there is enough battery left for the Peak period? Any thoughts gratefully received.
Thanks, Dave
2am - 11%
5am - 99%
6am - 94%
7am - 80.6%
8am - 75%
9am - 67%
10am - 61.2%
11am - 54.8%
Thanks, Dave
