I'm on Octopus flux export + import. Cheap import 2-5am and best export price 4pm-7pm.
Have 5kw solar, 7kwh batteries and inverter.
I've set up batteries to charge from 2am-5am.
What i'm trying to do is export all my 'spare' battery charge between 4-7pm for export payments. One easy way is to set up the battery to dump its full charge between 4-7pm. Since the import price before 4pm and after 7pm is slightly lower than the export price between 4-7pm, I think this is financially roughly equivalent (but slightly better) compared to saving the charge and using it in the evening afer 7pm.
However, if the battery is already low on charge at 4pm, this 'dump everything at 4pm' method will result in the battery running out (.e.g at 6pm) and me using the grid at peak rate (bad).
So one solution is for me to set up the battery to charge up from the grid between say 2-4pm. However, depending on the charge % I need that timer to ideally start earlier or later (which I'm unsure is possible). To guarantee a full battery at the start of 4pm, i'll need to start charging it at around 2pm which will often be pointless if the battery is already at 99% and will be topped up by solar anyway (although in this case, it'll cost me very little since its already nearly full), but it seems suboptimal?
Is there a trick I'm missing here? Is my maths correct? It seems like ideally I could set the battery to only charge up to 90% between 2-4pm and then let solar do the rest if the sun comes out but I'm not sure if this is possible. Or I don't bother charging from the grid between 2-4 and only dump excess power into the grid between 4-7 but again I'm unsure if this is possible either?
