andyriches
So i ended up getting the below
1kw complete solar system . The system consists of 4x250w panels 1x EPEver 2.4kwh continuous discharge hybrid none grid tied inverter.
The batteries i have are power safe 195APH and i have 4 of them.`
That's the inverter below.
www.sunstore.co.uk
![1687376437881.png 1687376437881.png](https://diysolarforum.com/data/attachments/153/153833-ad29b8fe7a80ae479be46ed1a6acf2e2.jpg)
![1687376546040.png 1687376546040.png](https://diysolarforum.com/data/attachments/153/153834-0f3c115bd69d64f081e95df058517292.jpg)
I have it all wired in now and all was good till i tried to run the heat pump, it turns on and runs but the compressor is quite noisy and it kills the battery's in a matter of 10/15 mins.
I thought i would have a good few hours running from them, it was drawing about 4 amps but the charge state fell very quick, but soon picked up again once the heat pump was turned off, its not a big heat pump, around 900 w.
Do i need a bigger battery bank ? We have some more power safe batteries i can get hold of but these are 12v 65aph and am i correct in saying you cant mix the APH in batteries ?
It is running the water flow pump with no issues at all, the guy who i got it from had it running his hot tub which will draw way more than my heat pump so i can only think its the batteries ?
Any help or ideas would be great
![www.sunstore.co.uk](https://www.sunstore.co.uk/wp-content/uploads/2019/12/Upower1.jpg)
EPEVER UP3000-M6322 24v 2400w inverter charger - Sunstore Solar
EPEVER UP3000-M6322 24v 2400w inverter charger The UPower series is a new type of the inverter/charger combining with solar & utility charging and AC output.
![www.sunstore.co.uk](https://www.sunstore.co.uk/wp-content/uploads/2018/06/64.png)
