I have 16 of the Envision 305ah, in a EEl case, they are on a balancer(Hel Tec) and a 200a seplos BMS from EEL(w/case). They have 10 cycles on them, and have a balance of 0.005-0.029 mv, under this setup. They are tied into 8x100ah packs (3x 48v eg4 lifepower, 2 x trophy 100ah eve, 2 x Jackipier 100ah, and a jdb /eg4 8 cell x 2. This is all feed from a SolArk 15k, I have 16 304ah EVEs on the way, #2 EEL box is already here.
The Envisions 12 of 16 had a little swelling, they will fit the EEL case, but will not do foam/spacers on all cells, have looked athe the system with a fluke thermal cammera in charge and discharge mode,(garage @90, all cells with 4.5amp charge(80A) temp was +2-3 deg F., discharge was at 4.0 per cell(64A) same 2-3 deg above ambient. I have had no cell leakage, boxed arrived in good condition. Hope this helps with someone battery build.
