Solarfun4jim
Solar seduced :-)
@Will Prowse
Any of the 'Tech heads' on here, that have the right equipment, up for running some experimental testing on a single lifepo4 cell?
A range of experiments plotted on a graph could be very illuminating(with regards specifically to solar charging and low C rates).
Keeping in mind, higher voltages drives the ion mobility and the proclamation by Will, that no degradation of the electrolyte happens until above 4.2v/cell, i thought the following tests could cover a lot of bases/outcomes and may provide a lot of guidance on future charging profile set ups.
I would love to do this myself, but as a newbie, i dont have the equipment necessary at this stage or the confidence in my abilities(as yet).
Anyone up for the challenge? Will P?
Thought these tests would be good....
Start with a 'single 3.2v cell' discharged to 2.5V each time(not a battery pack).
To compare how much, higher voltage (higher ion mobility) drives charging time…
Charge 200ah cell, 4.0v @ 60A (0.3C charge rate) (240w) disconnect at 3.6V level, so no 'cv stage' charge where amps drop to zero (how long to charge & then test total capacity gained discharging to 2.5v)
Charge 200ah cell, 3.8v @ 60A (0.3C charge rate) (228w) disconnect at 3.6V level, so no 'cv stage' charge where amps drop to zero (how long to charge & then test total capacity gained discharging to 2.5v)
Charge 200ah cell, 3.6v @ 60A (0.3C charge rate) (216w) disconnect at 3.6V level, should be able to get full cc/cv charge stage to zero amps (how long to charge & then test total capacity gained discharging to 2.5v)
Charge 200ah cell, 3.4v @ 60A (0.3C charge rate) (204w) disconnect at 3.4V level, should be able to get full cc/cv charge stage to zero amps (how long to charge & then test total capacity gained discharging to 2.5v)
To compare capacity gained, versus ‘charge rate’ at higher voltage input as per example 1 above.
Charge 200ah cell, 4.0v @ 20A (0.1C charge rate) (80w) disconnect at 3.6V level (how long to charge & then test total capacity gained discharging to 2.5v) – this should take 3x as long to charge, but how much does the lower charge rate affect capacity gained?
To compare same wattage input as first example…but at lower voltage
Charge 200ah cell, 3.4v @ 70.6A (240w) disconnect at 3.4V level (how long to charge & then test total capacity)
To compare charging using higher voltage but only to 3.4V cut off (aiming for 90% SOC capacity only)…
Charge 200ah cell, 4.0v @ 60A (0.3C charge rate) (240w) disconnect at 3.4V level so no cv stage charging (how long to charge & then test total capacity gained discharging to 2.5v)
NOTE: I trust this post wont be viewed as 'cheeky' and accepted in the spirt it was intended as regards experimentation. As i said earlier, i would conduct it myself, but that could be many months away !!!!
