CrossPike77
Hi All.
I've been tinkering on an off grid system for a barn workshop since 2020 lock down. Harbor Freight 25W kits strung together expanded to more robust components a yr later. Been trying to get to the point of just having lights on (and maybe a few small power tools for short bursts) on the solar, has become a new interest in having a diy solar generator for power down options. I will layout what I have done and my concerns with if I have done correct and what may need correction (willing and wanting to learn if I have done incorrect).
I have 4 100W Renogy Panels on all coming in with adapters and cable into a new 40Amp Mppt BougeRV charge controller. From there, I have a 2000W AC inverter. Connected to 4 batteries, 1 is a 100AH Gel Weize, and the other 3 are 75 AH Deep Cycle Marine batteries. One 12V 40Amp breaker on the solar in before controller. Breaker/Fuse from controller to bus bar. 1 - 200AMP fuse on the battery in to bus bar and 1 on the out to inverter. Shut off on battery bank main in before fuse.
I have done some small testing, I had a heat gun running for a couple minutes, a Harbor Freight router table for a few minutes. Both seemed to use some battery power and to 75%, and then it bounces right back to the 90's after turn off.
I tried plugging in my shop light array this morning ( there are around 10 LED shop lights at 42W each). The battery power started going down fast into the 50% range within a minute or so and after disconnecting, came right back into the 90's again moments later.
My question mainly is, Should I be expecting such a drastic drop in battery power? I feel the panels should be providing some power as I'm trying to draw for this usage. I feel like if I try to test out the LED lights for too many minutes, they won't stay on for long at the rate I witnessed. I plan to start with one light at a time until I see a drastic drop and know that's my threshold.
Is my bottleneck having two different types of batteries and I will see better results with multiple Weize gel instead? Currently they are daisy chained to each other, I have seen multiple batteries run to a common bus bar then out to distribution bus bar (Am I better of with this config?)
I'd like to try and run my fridge or deep freezer (saw a guy on youtube with similar specs run a chest freezer for 6 days, but his drop didn't seem so drastic on draw) if power goes down.
Any help or insight on my questions is greatly appreciated.
