I have an 8.2kW system comprised of 20 405w Talesun panels and 5 apsystems qs-1 micro inverters. 3 micros are on one string and 2 on the other. Both go to separate breakers in the sub-panel that feeds back to the main. For some reason one of the micro inverters will drop out to a low or zero output (the sampling window seems to be too short) and bounce right back up again. All four panels go down at the the same time at at the same voltage and it isn't shade causing it. A small number of times more than one micro inverter has dropped output at the same time. What I haven't done is check to see if they are on the same string or happening on each. That may help tell me what is wrong. Is there anything else I should check?
There seem a few possibilities to me. I'm in central texas and they are overheating and resetting. They get really, really hot.
There isn't an issue and occasionally an inverter loses communication with the ECU and then reconnects
Overvoltage for some reason. I do have fairly dirty power from my power company
Something I'm unaware of, lol
Any suggestions as to what might be causing this?
*** EDIT *** I went through my log this morning and most of the time the dropouts are occurring on the 3-inverter string but it has happened on both of the two-inverter strings in the last month or so. It has also done this when it wasn't nearly as hot so I'm not sure overheating is the answer, either.
