sgturner
- Jan 2, 2022
- 44
Hi and happy 4th!
I have a system, being installed, that consists of:
- Sol-Ark 12K
- 28 x 370W solar panels (PV)
- 6 x Fortress Power eFlex 5.4 batteries
- APSmart Rapid Shut Down (RSD).
The APSmart system consists of an RSD module per solar panel and an RSD Transmitter located in a plastic NEMA enclosure that sits next to the Sol-Ark. The Transmitter needs to be powered from 12V @ 800mA before the RSD modules and so PV will turn "on". The Sol-Ark has a 12V DC output that can be used to power the RSD transmitter, but according to the manual, it is limited to 100mA. The APSmart Transmitter kit comes with a 120VAC to 12V DC power supply, which I guess could be connected to the AC output of the Sol-Ark. This would mean that the Sol-Ark needs to be generating AC to turn on the PV. This means the grid needs to be "up" OR my batteries need to be in a state that they can supply enough power to turn on the inverter.
One of my reasons for installing this is to be able to weather any "grid down" situations that may happen from time to time in the California fire season. So I need to be able to turn on the PV with no Grid. This implies my batteries need to always have enough juice to turn on the inverter and so bootstrap the PV into operation. If I never let my batteries get below 20% SOC then I should be OK, right?
Is there a better way of doing this?.
Thanks!
- Sol-Ark 12K
Thanks!
