I used my new epoch 36 volt charger for the first time yesterday and all is not well.
I have been charging with a nice slow 300w 5 amp solar system and it never charged the cells at max voltage.
yesterday when I hooked up the new charger everything started out looking normal 3.248 max voltage to 3.241 min voltage across all the cells a .007 differential, very good I think.
I watched for 10-15 minutes and it never recorded higher than 3.255 on the highest cell to 3.248 on the lowest.
very good I thought.
I went out to the garden for 15-20 minutes and when I came back the charge on the highest cell was now 3.305 volts, I panicked and pulled the plug.
being a Sunday I couldn't get customer support.
now the big question DID I HURT MY BATTERY?
the readings this morning after sitting are 3.229v on the highest cell and 3.214 on the lowest well within safe charge limits but still a 0.015 spread, higher than the 0.007 that was the normal spread.
is it normal to charge higher than 3.265v while charging then taper off to below 3.265v when fully charged? I wouldn't think so? but what do I know.
don't know if this has anything to do with it but the battery is at 56% of charge now.
