Tatertot51804
- Jun 7, 2022
- 11
First off please ignore the rats nest of an install I have going on. I've only been playing with solar for about a year and it's in preparation for moving and becoming off grid so I've been experimenting with stuff to see how it's going to work for me. This wall has been redone 10 times probably lol. Once I move I plan to have a nice electrical room with everything mounted neatly and all of my wires run through panduit.
I am currently living in a 5th wheel camper and have an eg4 3000ehv inverter connected to 16 230w solar panels and 180ah of batteries. I have 3 redodo 100ah,1 amperetime and 8 valance 40ah. Every battery was fully charged with a 12v solar controller and once each group of 4 had been fully charged they were wired in parallel and charged again. After that all of the batteries were wired into their series groups. (the ampere time is in the group due to the same issue I'm having with the ampere time now)
I am having issues with some batteries being off from the others. I kind of expect it from the valance batteries. I did not capacity test those to match them. However with the redodo batteries being brand new I would expect those to all be internally balanced. The highest bulk setting I can do is 55.5v. Any higher than that and I end up with 1 battery hitting high voltage disconnect. When they finally do go into float 3 of the redodo go to 13.3 but one sits at 14.2. I swapped in an ampere time, tried again, and got the same issue. It doesn't matter what order the batteries are in when wired in series, that same battery goes high. Ive had these charging and discharging for months and it's not resolving itself. I figured after a lot of cycling the cells would balance inside each battery. I'm doing series setups because I'm poor and this allows me to buy batteries as I can afford them rather than coming up with 1000-1500 at one time.
Has anyone else had issues like this with their batteries? I do not currently have pictures of the voltages in question because the batteries are not fully charged right now.
