The VE.Bus BMS is
required, even if you have a single 12.8V battery. Without that, you have no charging/discharging protection at all. (and it's unclear to me whether the batteries will even "turn on" if no BMS is detected). But the nice thing is that you only need 1 BMS for the entire pack, since they can be interconnected/daisy chained in any way, so you only have 2 leads going into the BMS. (and here I'm referring to the low-voltage communication wires, not the main +/- current-carrying wires).
The SuperPack
cannot be connected in series, that's the main thing to keep in mind. You won't be ever able to connect in series to get 25.6V or 51.2V. If you're OK with that, and you're only ever planning on parallel connection, then its fine to go with that.
I'm bringing this up because I myself started with a 12.8V LifePO4 system and soon after switched around my configuration to 25.6V because I noticed the current draw at 12.8V for my loads was too high (plus much less efficiency at 12.8V for higher powered loads). If I didn't have a batteries that weren't able to connect in series, I would've been stuck at 12.8V, and would've had to lower my power consumption.
10.5V * 150A = 1575W max continuous.
(and here I'm using the lowest voltage possible for LifePO4 to simulate capabilites at near 0% SoC. A fully-charged battery can give you 14.6V * 150A = 2190W. But always look at the min, and not the max. Current
increases dramatically as the SoC falls below 14%, to maintain constant power).
After inverter losses (let's say 88%, which is what I'm getting with a high-quality inverter), your max power output will be
1386W. Only you can decide whether that's enough power for you.
As for bluetooth (BMV-712) or no bluetooth (BMW-700/702), that's a personal decision. All I can say is that I have the BMV-712 and I can't imaging not having the Bluetooth. Configuring the thing on the tiny 5-segment display with scrolling text is super annoying. It's so much nicer via the VictronConnect bluetooth app. If you go with the non-bluetooth models, I highly recommend getting a VE.Direct to USB cables so you can program the BMV via a computer. Once you program it once, it should be "hands off" after that.
One final note about bluetooth:
each Smart battery has its own bluetooth. I don't think it can be turned off. Just something to keep in mind.
