Hi, i have a growatt 5kw inverter and a battery 48V 100A/h connected to it, my growatt setting was on charge only from solar Unfortunately no sun for 3 days and the battery was discharged completed ( O V ). The battery is protected by an internal BMS shutting the battery if if it is too low normally i think.
No i cant resart the inverter because the battery is flat. Can i rechargs the battery alone with a charger 48v ?
Why the BMS did not do the job? The solar panels are OK , i have checked the voltage. Many thanks for suggestions...
Jean-Louis Haye South Africa
