Battery Connection Questions
Jet
How should I attach the 6awg wire to to the batter. I thought the vehicle s battery wires were claimed together. I was going to buy a terminal clamp with an extra hole however the battery vehicles battery cable is a different style. Should I just add the wire on top of the others on the terminal post?
Will there be problems if I ground the negative side of my 24V house battery bank if my vehicle's battery/system is 12v?
Should I ground the negative side from the negative battery terminal or the lynx distribution bus bar. The negative bus will be 4.5 feet from the battery.
I'm going to use a 12V blower fan to keep the DC-DC charger cool. I'm thinking about attaching the wire from the fan to the positive from the vehicle to DC-DC charger using a fuse of course. Would it be ok to ground the negative from the fan to chassis or should I run a small wire back to the 12V battery?
Photo didn't seem to upload.
