Jim Burrow
- Jun 27, 2020
- 516
2 August 2020 – 12 Battery equalization and Voltage (2 batteries)
That I would sure my battery equalization procedure.
Today I thought I would take my (2) 12volt batteries I found in the throw-away/recycle bin out at my local airport to do my MPP testing. I’ve been testing the MPP to see how it will perform under various conditions with respect to the loads that my house on the average draws. – roughly 300 to 5oo watts depending on what I have on and no heavy appliances like a microwave, washer/drier, air conditioner, or heater.
I’m surprised that the batteries are holding up real well since I didn’t bother with voltage and capacity equalization that everyone does with their BMS units.
Starting my battery equalization, (note I’m not using any BMS, just old fashion method) the red battery is holding a voltage of 12.4v, and the blue battery holding at 13.0v with 420 ma going from the blue battery to the red battery.
When the voltage of the two batteries is the same, there should be no current flowing between the two batteries. So, in theory, the two batteries should be in equilibrium or both with the same voltage and capacity. I’m assuming both batteries are 35-ah as I couldn’t read what they were, but they are small for aircraft.
Also, note the only thing that I saw wrong with these two batteries is that they built up pressure inside and the sides bulged out.
Now that these batteries are connected in serious for 24v to my MPP controller/inverter, if one battery can’t hold a charge after a period of time, there will be a major drop in battery voltage.
