wopachop
I have two flooded 6v batteries on a trailer tongue. Outside temps are around 30-50F. In the next couple years i plan to switch to lithium and move the batteries indoors to stable temps. For now i took a quick look at battery heating pads. Not the cheapest things and in a few months its going to be 90F outside and wont need them.
Instead of buying a 60watt heating pad, what if i hooked up my 60watt battery tender to the inverter powered by the same batteries? Do you think a 60watt charge and discharge would be enough to raise the temp of the batteries? Or will most of the heat production and heat loss happen at the inverter, making this idea useless?
The goal would be to warm the batteries a bit before putting a larger load on the inverter. I would definitely unhook the charger while not in use. Solar will charge the batteries during the day. More looking for a cheap and temporary way to warm up my 6v's until i switch to lithium and can move the batteries inside.
