Battery Levels Belo 50 percent
Neilthurston99
Lytham
Hello
I am an absolute newbie to solar energy.
I am using lead acid batteries which I understand should not be run on less than 50 percent of charge to avoid damage to the batteries.
I am setting up a solar powered system remotely and will probably visit around once per week.
I have bought a 1000w Renogy Inverter and yet to buy a battery shunt / monitor system.
Any guidance on how I can set up my system so battery charge levels do not fall below 50 percent would be much appreciated.
Cheers
Neil
Hello
Cheers
Neil
Lots of different ways.
You'll want an inverter/charger/charge controller that has adjustable settings for voltage cutoff if that's what you're after.
It's probably non-adjustable on the renogy.
Enlighten us as to your power needs and ultimate goal.
I would advise you to not buy any equipment yet until you have done more research. This way you'll avoid purchasing stuff that isn't going to meet your needs.?
