I am swapping 2- 6 volt, 230ah, deep cycle lead acid for 2- 12 volt lifepo4 100ah in parallel. It is becoming a bit more complicated than a direct swap. Is there a simple way to monitor the lifepo4 batteries? I am fusing each solar-powered panel to 30a mppt charge controller, charge controller to busbar positive, each battery positive to busbar positive. Is a fuse also necessary to rv charge controller/ fuse panel? Thanks.
