I just built a DIY battery bank using 16 Eve 304Ah cells and an overkill solar BMS. I am not quite sure what settings to put into the inverter for the battery. Can anyone offer some recommendations?
You will select USE for mode 5 and add your cut in/out voltages and mode 02 for charging current. I use 48 for transitioning from bypass (grid) to battery mode and 46V to transfer back to grid.
