Hi,
I just finally connected together my solar system and the Smartsolar does not turn on after connected to a battery. I suppose it should turn on the small light, but it doesn't. I checked the voltage of the battery (24 volt battery) and it shows only around 2 volts. When connected with the MPPT and an inverter, it shows a little bit lower voltage then when not connected to anything. Also the voltage of the battery seems to be dropping every few minutes when it's connected to the inverter and the MPPT. Did they send me a dead battery, or what could be the problem? I atteched a picture of my system
Best regards
Jan
Best regards
Jan
