New here. Need some help.
Recently converted from lead acid to lithium batteries. I built two banks of 3.2 EVE LIFEPO4 batteries (48 volt system, so 16 battery each bank) with each battery having its own JDB bms 7-20s.
I hooked up the bms’s in parallel, I have read some say do not do that other say it works fine. But mine charges fine with the solar arrays, but at night only one battery is discharging. The bright blue led is on on the one that is working and not on on the one that is not working. If I take the bms out of the system and then hook it back up it work fine till the next night, then I have the same issue.
Would appreciate some advice. Thanks
