Sunpower11
Hello All,
Complete beginner looking for generator recommendations based on a few specific needs. I'm open to both solar and dual fuel, but mainly drawn to solar due to potential fuel shortages during an outage and lack of carbon monoxide concerns. I also have some mobility challenges so looking for something that is somewhat portable or that a neighbor could assist with. In terms of power needs, considering two options: 1) Ideally, backup power for whole house (1300 sq ft), 2) At a minimum, backup power for full size fridge + one full size freezer and possibly a window A/C unit). I am not so much worried about lights/electronics, just want to be able to save food and heat/cool house to a reasonable level. I would like to keep the cost at or below $4K, including installing a transfer switch if needed. I've been looking primarily at the EcoFlow Delta Pro or Delta 2 Max. Would either of these be sufficient? If so, what specific recommendations would you have? Also, are there any important questions I haven't considered?
My wife and I would like to stay in our current home for awhile, but aren't sure if we will be here long-term, so we're probably going to hold off on solar panels for awhile. Any recommendations on battery packs for solar? It seems like Ecoflow has fairly regular sales. Finally, I've learned a lot from Youtube, but still would appreciate advice of whether I should get an inverter, the most accurate method to calculate wattage, surge needs, etc. Thanks in advance for your insights!
