Jsbgraphics
- Jul 3, 2022
- 7
I have just recently joined the forum and would like to run by the people in the know here what I'd like to do and get any help possible.
I have a generator interlock installed and a small 4,000 watt gas generator that supplies power in an emergency (just barely). I run basic necessities off of this when the power fails. Lights, receptacles, one chest freezer and regular Fridge and my well pump.
I can't justify buying a bigger gas generator with things going the way they are with gas etc.
I'd like to install some solar that would handle this load in an emergency, and potentially run these systems full time. Below is what I am looking at:
My plan is to purchase a Sungold Power All in one 48 volt inverter charger: https://sungoldpower.com/collection...-hybrid-solar-inverter-split-phase-120-240vac
and at least one 48 volt Lifepo4 200 AH battery.
I am a bit confused about calculating the correct number / type of panels and the best way to connect them for this system. I have 3 100 watt panels and use one to power a small 12 volt system in my shop. (tool battery charging and few 12 volt lights etc.
The ultimate goal is to install the all in one Inverter Charger, the battery bank, and a satisfactory PV array and then have my electrician tie it into something like a Reliance transfer switch so that I can run the above systems off the solar either during a power outage or as I said full time.
The Sungold unit can be grid tied etc. but I have no interest in that, this would be a strictly off grid system.
Just trying to wrap my head around the whole system and understand what I need to do and how to do it before investing.
