Sounds like you need to refine your requirements.I will be using a washing machine on this setup so 1000w would be a bit small.
48 volts is more efficient that 24 volts.From what ive seen 24v is more efficient than 12v system altho im new to this but also i want to eventually expalnd on the system over time.
Yea the 48v is more efficient than 24v but im trying to balance effiency and costSounds like you need to refine your requirements.
You might consider an AIO. I see the one I am using is even cheaper now at $418 with 15% off. free shipping. https://easunpower.com/products/eas...lar-inverter-24v-pure-sine-wave-inverter-100a I actually have 2 of them. (Bought another one as a spare when it was $449 with 15% off a month back).I will be using a washing machine on this setup so 1000w would be a bit small. From what ive seen 24v is more efficient than 12v system altho im new to this but also i want to eventually expalnd on the system over time. Currenty i have 1 345w 24v solar panel 60A makeskyblue charge controller and 4 100ah 12v lifepo4 battries. So im trying to figure out which decent inverter i can get for around 450 tht can run my off grid setup.
How long have u been using this and what r u using it to run? How does it handle inductive loads?You might consider an AIO. I see the one I am using is even cheaper now at $418 with 15% off. free shipping. https://easunpower.com/products/eas...lar-inverter-24v-pure-sine-wave-inverter-100a I actually have 2 of them. (Bought another one as a spare when it was $449 with 15% off a month back).
Since August. I have a review of it in the off grid inverter forum. https://diysolarforum.com/threads/e...rter-1st-week-review-and-monthly-recap.45138/How long have u been using this and what r u using it to run? How does it handle inductive loads?
Ok i will check it outSince August. I have a review of it in the off grid inverter forum. https://diysolarforum.com/threads/e...rter-1st-week-review-and-monthly-recap.45138/
You may get a reality-check here. What happens when you press the "ON" button and the inverter shuts off because of overload? You throw away everything you paid for and start over? Believe me, I've seen it happen here more than once.Yea the 48v is more efficient than 24v but im trying to balance effiency and cost
Can u send me the link to this?well Will Prouse on his mobile forum recommends the Giandel 24v 3000w.
