Smack3
- Jul 20, 2021
- 7
I am another newbie trying to clarify somethings so I do not let the smoke out of my new investment. I ordered a bluetti ac200 and 2- 200watt/24volt panels from rich solar (rsm200d), but i am considering ordering 2 more panels to max out the input of the bluetti and reduce charging time. I have read several other threads that seem to have conflicting info. I think the setup i want is 2s2p that hopefully will provide 90.8 Voc and 10.64 amp input that is close to the limit if my diagram is correct. I read in one post that you CAN overpanel with more watts and the bluetti will just ignore the overage, and then i saw another answer that said it will fry the bluetti ac200 if you try to push past the 700watt limit. can someone confirm before i order two more panels? I have not received any of the above yet so i cannot really test anything at this point. Also if my drawing is wrong please correct me about the math and how serial vs parallel is calculated. By the way, this is an awesome forum and i am learning a lot but not quite there so any help is appreciated.
link to rich solar panels https://richsolar.com/products/200-watt-24-volt-solar-panel
