True. I was thinking of going with the 5000 Quattro, but yes i agree the 3000 Multiplus would be sufficient. The increase in the charge rate of the 5000 Quattro is very tempting, although my access to larger plugs is limited and when i do have it is usually overnight which defeats the purpose of charging faster but i can see times when that would be useful.
The air conditioner on my current build, a 13,500 btu Penguin ii, draws between 1,300W & 2,160W while the compressor is engaged depending on ambient temps. I usually see about 1600W on average as the van and night cools the compressor draws less. Just the fan draws about 480W, but I am eliminating that by going with a separate control panel for it so that it shuts off when the compressor is off. The compressor in my experience, depending on the setting and ambient temps, runs about 35% of the time on warm nights, I'm from South Florida so that is somewhat often. So for example at 12v it draws about 150a. The bank consists of 1120ah÷160a= 7 hours runtime. I figure it will be good for about two 2 full nights.
I have considered using solar but due to my consumption rates it almost seems futile and not worth the extra $$.
Again all your thoughts are welcomed and very much appreciated.
