Yes 7P4S. We have 12v in the boat that's why .6000W/12V/.85 = 588A
I doubt even your cell interconnects (bus bars) can handle that current unless you've gotten very creative with custom bus bars.
Do you mean DIY 2000Ah 12V battery?
Why on earth did you go with 12V?
I'm assuming you have several cells in parallel, something like 7P4S if using 280Ah cells. You likely need to break your bank down into individual 4S batteries, each with their own BMS.
Does that mean big dc loads like bow thrusters and windlass?Yes 7P4S. We have 12v in the boat that's why .
No we cook electric 240v. All the other systems are 12v like windlassesDoes that mean big dc loads like bow thrusters and windlass?
If I'm understanding correctly on top of the ~600 amps to run the inverters you have to supply the windlass as well which will be a significant pure dc draw.No we cook electric 240v. All the other systems are 12v like windlasses
Thanks.If I'm understanding correctly on top of the ~600 amps to run the inverters you have to supply the windlass as well which will be a significant pure dc draw.
Will be following your work on this one.
Max 5600watt48V would have been a better choice. I'm guessing you don't want to change the inverters now?
What is the FLA (full load amperage) of the stove/kitchen appliances in the RV?
My plan is 3* 4s. So each pack has 8 cells of 304amp. Parallel on 1 bus bar. The 2 Multiplus in parallel and other things like led lights, navigation equipment etc connected to the bus bar. For the winches I make a 4s pack stand alone. what do you think?Break it out into 7X 4S batteries, each with their own 120A BMS.
Thanks.
Max 5600watt
3 * (4s2p) doesn't that give more than 360a?
Lofrans anchorwinch 1700watt. So I thought 1700/12= 150amp (+-)
Each battery is limited by its BMS. Each battery BMS is limited to 120A. 120A * 3 = 360A
150A is the RUN current. When it starts, there is a much larger surge current.
Thanks.
Max 5600watt
Thanks I have to find out how much they useI'd put the Multis on 1 bank and everything else together.......navigation equip. eats up a chunk of power.
