Hi, great forum,
To all senior and expertise.. Help me.
I have battery charging module XH-M604, 6v-30v input supply, It has relay to auto cut-off battery charging (example 10.8V start and stop charging at 12.8v).
My question is the led display panel & led indicator operates using the 12V battery.
Now i remove the led indicator to save battery because it will light up forever until battery run out its charges. How & where can i connect one Led as indicator (led light up upon inserting 12v charger)
Tried to connect at the relay, it light up but wont shut off when turn off the 12v adapter/charger. Its Like the led connection intact with the battery circuit line .
Appreciate any help
Appreciate any help
