gray webber
- Feb 4, 2022
- 202
After weeks of looking for a low temp charge protection to protect my batteries if the worst happened and my heated box fails, I have found nothing that would not pull power off the batteries to hold a relay coil on. Ok, so if I build my own batteries, is there a good low temp protection out there?
After watching dozens of YT videos I saw that Will P. Used Overkill Solar BMS that has this feature and in a quality package. Ok, but the highest current charge and discharge is 100 A at 24 volts. Not enough. Then I recall seeing where Will had paralleled two BMS units and they worked well and allowed double the charge and discharge rate.
Will two Overkill BMS paralleled work for my needs of 150-200a and still function in the low temp disconnect function?
If this can be done then I guess a raw cell battery build is in my future
