Daly BMS
Merc814
Once again I am befuddled by this thing. It's done good in the fact it cutoff the charging MOS at low temperature - great, thank you. Now I've warmed the van, and the temperature reading is above the cutoff - but it is still refusing to allow my batteries to charge. Does anyone know the 'correct' procedure to get the Daly to retract its low temp charging cut off?
If I disconnect the solar the charging MOS switches back on, as soon as I reconnect and the SC attempts to charge my batteries, the protection kick in again despite it registering a temp above the cutt off (0 degrees C).
Incomprehensible
