I have a 24V 500AH battery pack constructed of 8 LIFEPO4 cells connected in series with copper buss bars. I am also using a 300AMP DALY BMS with the pack. My inverter is a Victron Quattro 24/5000/120. My issue is when I run a high AC load, really anything over 500watts, the Inverter shuts off with a "Low Voltage" error code. I worked with Victron to make sure all my inverter settings are correct so the only thing left is the battery pack and BMS. Using a heat gun to test, when I turn it, on my 12V LED light strip in the electronics compartment dims but one the Inverter shuts off the light comes back on to full brightness. I am also using a Victron Orion DC-DC converter for my 12V distribution. The Victron Smart Shunt is reading the battery pack at 28.5V's when I start the test. Using a volt meter, the Inverters input does drop to ~ 24V's when the heat gun is turned on. Low voltage cutoff on the Inverter is set for 18.6V per Victron's recommendation. Is my issue with the BMS or the battery pack? What is the best way to test without buying another BMS?
