What is the best way to limit the charge controller to keep the SOC between 20% and 80%, never going above that or below that?
As I understand, the LifePo4 cells like that range but don't like both extremes.
The reason I ask, is that I use very little electricity during the day and would like my panels to supply that, 2X250w, my battery pack is a 24 V, 280 amp hour, with my usage of both panels it continuously charges the battery, up above 80%, going to the full capacity that the charge controller is set to.
I want to continuously operate within the 20 to 80% range, to keep the battery healthy. Otherwise it'll constantly be up to 90% or more.
Can I change the settings on the charge controller to make it, force it, to operate between the 20% and 80% range? Or is this not good for the whole system.
As it is, I have turned off the charge on the BMS, charge MOSFET, to stop the battery from receiving a charge yet using the panels to supply all my needs, and allow discharge from battery if it should come to that during the day.
