Hello everyone.
I'm having some difficulties here with my solar system. I only have couple days with it and I'm new to this. I have 2 jbd 200amp bms. Each with 16 batteries. But one of the BMS's indicates charge overcurrent. And usually starts at 50% batteries capacity. So it shuts down and couple seconds later starts up again and shuts down and on. During the day it still reaches 85-90% charge. But after Sun is down switches are on But there is no discharge. Only from the other bms. So of I turn of the working bms the other ones comes on. And if I switch the other on this one shuts down. We have the 2 sets of batteries with each fuse ran through one same wire. Would that be a problem? I have no idea where to go from here. And batteries were top balanced. They actually keep balanced even when it says current overcharged
