Yep. Can't be meaningful without knowing how big the battery is.
Yep. Periodic synchronization to 100% OR sufficient charging to achieve near 100% without meeting the "charged" criteria, i.e., the BMS literally counts past 100% and resets to 100%.
what BMS?
24S? what application?
This is generally not used for LFP. The flatness of the voltage curve makes this wildly inaccurate. This is very common and accurate for Lithium NMC, LMO, NCA, etc... the "3.6-3.7V" nominal Lithium chemistries.
Yep. In the vast majority of cases, the BMS synchronizes to 100% with regular charges to full.
NiMH is even worse than LFP, and NiMH is never fully charged or even close in HEV applications. Essentially, they have detailed "lookup" tables of voltage, current and temperature that are combined with current counting to estimate SoC. It's pretty amusing to watch SoC calculations made by the car jump wildly due to a significant temperature range even though it hasn't moved since the last calculation was made.
I suspect the NiMH method is also used for LFP and may be applied to other lithium chemistries as they need to track state of health, i.e., if the coulomb count says you're at 50%, but the voltage/current/temperature data says it's actually lower, it would estimate the reduced capacity and a less than 100% SoH.
