String Anemometer
Never heard of this being done...so a Will's Forum first! Or, it just might not work.
A taunt string in the wind should vibrate at a given frequency. You should be able to correlate the amplitude of the wave to the wind speed.
If one end of the string is affixed to a piezo-electric crystal, the amplitude should be measurable by the voltage.
I can see where Temperature would change the string frequency, but the amplitude should still be related to the wind speed. A string temperature correction factor? Of course, kudos to you as this device can now get both wind speed (voltage magnitude) and temperature (voltage frequency)!Unless you use a very special string it'll act more like a thermometer than an anemometer ? but +1 for originality.
I keep hearing a 3D printer is the gizmo you never knew you needed until you have one. Of course, I want one but don't really have a need for it. <sigh> (even the string anemometer wouldn't really need a 3d printer). So why don't I just get one? Well ... see Will's post New tool.I have a few needed for mine but looking local. Have some here at work but I will not use it for personal use. Years ago I was going to get a 3D printer but didnt need more on my plate as projects go.
I suspect the bigger problem is low wind speeds would only create a vibration in the lightest possible guage of string (e.g., thinner than a hair). I know the crystals are pretty sensitive...but possibly not that sensitive.
I'm not seeing the wind direction, could you run that by me again?
or perhaps they're in a clear vaccum tube?
the changing tension problem could be resolved by using a fixed weight.
Anybody got a 3D printer that can do all that?
That's why it says the crystal is measuring strain rather than frequency for the solar radiation....But then they wouldn't vibrate anymore...
With a fixed mass it would have to be calibrated to the local gravitational field for accuracy, so I don't see that. It wouldn't work in zero-g either (but honestly, if there's a strong wind in a space ship you got bigger problems)....That way you can measure changes in gravity too...
Theoretically it should be possible. Once you have the experimental data you could correlate it to known data and come up with a formula to interpret the data. The mark of a good measuring tool is that it is consistent over time. That is a 25 mph wind speed always give you the same amplitude repeatedly over years of use. I suspect that has more to do with the material science of the "string"....K, to many variables that are unknown.
Think you might be on to something. Of course, your control is to measure the wind speed with something else and calibrate the vibrations using that. The lookup table could account for all the other variables. The vacuum comment makes me wonder if one we've omitted is altitude/density. A 25 knot wind on Mount Everest is going to vibrate that string at a lower frequency than one at sea level, no? I'm also wondering if Heisenberg isn't a work here. Can we measure it without changing what it is we're measuring?That's why it says the crystal is measuring strain rather than frequency for the solar radiation.
The Humor section is the next thread down.
Just because no one has ever done it before doesn't mean it can't be done.
Theoretically it should be possible. Once you have the experimental data you could correlate it to known data and come up with a formula to interpret the data. The real question is would it be consistent? That is a 25 mph wind speed always give you the same amplitude repeatedly over years of use. I suspect that has more to do with the material science of the "string".
I'm sure people laughed at sonic anemometers at first, but they have consistent data and so are very reliable, and can give you wind direction.
Wait? Why are people still laughing???
... in addition to the level of boredom we're experiencing, as evidenced (measured?) by this thread (aka "a string").The problem is the difference between theorically and practically...
Preee-cisely. Or I've left a tool sitting on top of my inverter and it falls off and shorts the bus bars when go over a bump. Yeah, that kind of almost-everyday scenario.Dhowman : Bus bar covers - So something flat that snaps down on top and covers the terminal post? Can survive a wrench strike?
