mikefitz
Solar Wizard
- May 28, 2020
- 3,166
With 2AWG perhaps better to use 200A fuses.. I guess the BMS is rated for 200 amps maximum.But the 250A sizing seems high in my (in)experience.
A second set of buss bars would be a good idea. It's a big battery bank at 12 volts. What is the expected load current ?Do I need to get second set of Busbars. One set for paralleling the batteries, second set for Loads with a shut off switch in-between so I can completely isolate my batteries?
If high amps you will need a quality isolation switch, consider the BlueSea range.
