You could probably "hang" them with proper brackets without much effort. If you could "hinge" them for 2 or 3 angles to squeeze more juice out, may be worth it. Alternatively, is using bi-facials and painting the bricks white... (dunno if I would, I like red brick, somehow, it would just be wrong).
There are several mounting options available commercially, Even DIY using stock aluminum & rails is quite possible. Secured anchoring into the walls will be the key. Running PVC conduit for the panels wires etc, can also run along the wall till it has to get to your equipment. Depending on how many panels & their layout (portrait or landscape). For example, having 4 panels on an adjustable set (even the bigger 400+W) is not hard to manage by hand.
There are several examples here with a lot of creativity & KISS applied to boot.
Perfect example above, UNIstrut is available in bog-big & online and has all sorts of accessories to do stuff. Not crazy expensive either...
