you can hack your 20V battery pack, by opening them and replacing the cell (usually 2000MAh cells) by LG 3500mAH cells.
or you can 3d print and extension wall (between top and bottom of case) to add a 2nd pack of cell, doubling capacity.
20/40V pack are usually super expensive and if they are not , probably this is a scam claiming capacity that is not delivered.
I use the one from FERREX that are pretty cheap (while capacity is average)
the 20V 2A is only 20$ and the 20/40V 5Ah is 40$.
The 20/40 has misleading sticker since it is only a two packs 20V 2.5Ah (and even the 20V is misleading since it is really 18.5V)
so you do not get 40V at 5Ah, you get 40V at 2.5Ah or 20V at 5Ah (100W for the big pack).
if you want to power an inverter, 100W per pack is obvioulsy not a lot, and you would need a lot of battery
to get a reasonable amount of power for a reasonable duration.
So unless you get dozen of the big pack, i am not sure it worth the effort.
I will probably try to upgrade one of my 20V 2Ah pack with LG MJ1 3500MAh cell.
the cell is about 5$ each, so for the price of the original pack you got almost twice the power (3.5 instead 2)
I found a german guy who is selling 3D printed adapters (a bit expensive but really well done).
Adapter for Aldi Ferrex battery to use the battery voltage on other devices. Ideal for camping or lighting with LED technology
www.akkuhalter.de
