Shamoke
- Sep 15, 2021
- 27
Hope this is the correct forum for this.
I am rehabbing a double wide mobile home and want to build a whole home solar backup system. I've been looking to use EG4 inverter(s) and battery(s) along with solar panels on an adjustable ground mount. I am undecided on the equipment I am going to use and have concerns about compatibility.
1. On the inverter side I am thinking about using 2 x eg4 6000XP or 1 x 12KPV. I know the 12KPV is newer and more capable but costs a lot more too. I can buy two of the 6000xp's for less than one of the 12KPV's and have a safety backup if one stops working, I.E. Still have some power if/when one goes down.
2. The battery I'm thinking about is the EG4 Powerpro. I can start with one and expand later as I can afford to.
3. Panels: I have 10 370 Aptos DNA-120-BF26 370 watt panels now and had planned to buy more but they are no longer available. this leads me to question if I could use another panel in conjunction with the 370 watt panels with the inverters listed above, would it create any issues with different amp and voltages coming into the inverters.
If I have two inverters and max out one with a single solar array could I use a second array with different amp and voltage ratings with the other inverter without causing any issues? Would that cause any issues with having more than one battery? If I have two inverters and two batteries do I connect both batteries to the first inverter or have a single battery for each inverter?
I know I am throwing a lot of questions out there and I do appreciate any and all responses.
