DavidP40
Hi! Considering a house with solar panels on the roof but without experience it's hard to know what the pitfalls are going to be!
Here's what I know:
- no "rent a roof" scheme - the panels etc. are included in the sale
- they were fitted in 2011 and the installer's documentation and guarantees are in the property
- Reading these, there are 22 panels, it's rated as a 3.9kW system.
- There's a Growatt inverter on the garage wall and I can see an Elster A100C meter next to the CU. Didn't spot any other equipment other than a number of rotary switches.
- The documentation says "you should apply for FIT with your energy supplier" but there's no actual documentation about the FIT registration
- it's a probate sale, so quite likely difficult to get the sort of info you might ask of an in-situ owner
I can see how FIT works, and that the FIT rates in 2011 were very healthy, but it's a worry that there's no documentary evidence of the registration. No idea if the system is working either. Not much idea about how this system would have operated either - Google can tell me about current solar installations, but I imagine things have moved on.
What should I be asking and worrying about in this situation?
TIA
David
Here's what I know:
TIA
David
