CALIFORNIA residents.Please take a minute to make a public comment on NEM3.0 proposal
Duxa
Public comments can be made here: https://apps.cpuc.ca.gov/apex/f?p=401:56:0::NO:RP,57,RIR:P5_PROCEEDING_SELECT:R2008020
Public comments can be read here - https://apps.cpuc.ca.gov/apex/f?p=401:65:0::NO:::
Summary of NEM 3.0 proposal:
  1. If you want to go solar in CA but have not, the time to do so is now! You have until at least May 28th to receive PTO and be grandfathered into NEM 2.0 for 15 years.
  2. The one exception to this is if you are on CARE or FERA, you can actually receive bill credits and not pay the monthly solar fees. The benefit is $4.36-$5.25 (for PG&E and SCE, there is no incentive for SDG&E) per kW per month for ten years From the language of the proposal, you only need to qualify, not actually be on either of these programs. Check your eligibility here: https://www.cpuc.ca.gov/fera/
  3. If you have gone solar and are grandfathered into NEM 1 or 2, your grandfathering window has been reduced to 15 years from the date of PTO, not the date NEM goes into effect.
  4. The value of NEM credits is going down to roughly 5 cents per kWh. There is no way to calculate it more accurately than that for now until we start seeing utility rate sheets with updated rates.
  5. If you have a problem with this utility-backed, anti-competitive money grab, and are located in CA, please leave a public
Source -
