12V 206Ah LiFePO4 Lithium Iron Phosphate Battery Pack-OUT OF STOCK, NOT ACCEPT ORDERS NOW
OUT OF STOCK, NOT ACCEPT ORDERS NOW. RESTOCK AT THE END OF FEBRUARY. 12.8V 206Ah Lithium LiFePO4 Deep Cycle Rechargeable Battery. Built-in Smart Battery Management System,Support Batteries Connect in Series or Parallel. Low Temperature or High Temperature Disconnect. 3000~8000 Cycles Life. 7...
www.sokbattery.com
Can i charge the sok 200ah battery with a standard car battery charger? (pic attached)
Once its charged i intend to connect it via an anderson connector cable with jumper clamps to my lead acid agm battery box(pic attached) for extra capacity. doable? anything to watch out for? im guessing they should be disconnected from each other while charging?
I wont be connecting solar panels to this, just want to charge each unit in my house and then take them camping.
Thanks
