Can I connect a shunt in between JK BMS and negative pole with short alu bar?
Enduro
As in the title: can I connect a shunt in between JK BMS and negative pole with a short (max. 40mm) alu bar (20x2mm).
Bold on shunt is 10 mm and lugs on cables are 6mm
Yep, but that's not the question.
You sure?
What is the "negative pole" to you?
I interpret that as the negative pole of the battery, so you are asking if you can put a negative shunt between the battery and BMS. That answer is no.
Treating this like a wire gauge question: 20x2mm has a cross sectional area of 40mmSq which is close to 1 AWG (42.4).
Lets assume 100A running through it at 12V.
Such a short length will have minimal voltage drop - about 0.1%
Heat will also be reasonable at ~12degC or 20degF above ambient.
It will function much like a 3 AWG copper bar and should be fine.
I'd consider the max ampacity around 160-170A for that bar based on NEC chart 310.15(B)(17) in free air for ~1 AWG aluminum.
For example, 200A would generate ~50 degC or 85 degF above ambient which will be plenty hot to touch.
running the numbers for myself...
20mm x 2mm = 40mm^2
Al is about 60% the conductivity of Cu.
.6 * 40mm^2 = 24mm^2
3awg is 26.7mm^2, so it's pretty close.
Personally, if you have more of the aluminum, I'd double it up.
Aggressively scuff both sides with scotchbrite or sandpaper to remove oxide. Apply NO-OX-ID A-special to all contact faces. I would do the prep and NO-OX to even a single bar installation.
Aluminum is a good conductor especially when you factor in the price of copper. However, it's prone to surface oxides that reduce conductivity. Corrosion prevention is key.
