JustPractical
- Aug 31, 2021
- 106
Finally wiring in my Growatt12k to my four paralleled EG4 LIFEPO4's. I have no load on anything yet. To bring the batteries up to charge, my plan was to conenct the BMS cable from the Growatt to ONE of the batteries, set the battery to master, and then charge it with the Growatt. Then power everything down, set the next battery in the rack to master, connect the BMS cable, and charge it. I was going to work my way through all 4, bringing each up to charge. THEN, I was going to shut all down, connect up all BMS cables, give each battery a unique ID, and power everything up (all four batteries and then inverter). I'm doing this so that all batteries start out at similar charge (they are paralleled). I believe this is best. Opinions? Not necessary? Reminder - right now there is no load. Sidenote - I do not own a charger, so do not currently have another method to charge the batteries.
