Exactly. You can attemp to overload all day long and it will stay within limits (plus/minus measurement accuracy).This is not a valid concern. Once again, panels do not "push" current, they will only supply what is pulled from them.
Most likely you'll hit the max current limit long before you get anywhere near max power. You'd have to match your string voltage exceptionally well to the inverter to get limited on power.
In fact thats what I do(connect more than rated power). I currently have 6s2p 585W bifacial panels connected to an inverter that is 6000W max on its mppt input. Thats 7kW peak. Almost 8kW if you give them extra 10% for bifaciality.
And almost all day long I max out the mppt current at 18.5A and ~245V.
