SenileOldGit
- Oct 15, 2022
- 320
I have two 6kW PV strings, and two 5kW inverters running in parallel, and I was thinking about buying a third inverter to run in parallel, to a) reduce the total load on each inverter, and b) allow me to use over 10kW at one time in the house if I need to.
I don't want to have to dig up my patio again to lay a third armoured cable for a third string - so my question is, can I run three all in one inverters (MPP Solar PIP5048MKX) in parallel, with only two having PV input?
