Bluedog225
Texas
- Nov 18, 2019
- 2,921
I’ve got a little 12 volt workshop lighting system, radio, small and load tools occasionally. 200 amp SOK, Victron controller, and Victron 1200 watt inverter.
It’s all inside (except for the solar panels).
This little system will never be connected to anything else.
Instinct tells me I need a ground (as does the Victron manual).
Can I drill a little hole in the slab and pound a ground rod down on the inside of the shop? I’ve never seen this in real life. Otherwise, I’d need to go sidewise through a 10” concrete wall then into the ground outside.
Thanks
Thanks
