PaulLad
- Jul 14, 2020
- 169
- Q6: If I replace the included MPPT module for a batteries expansion, how much solar input can I use when the EB240 is unhooked from the expansion batteries and is in stand-alone mode?
A:
The EB240 could have a maximum of 500W from solar panels without MPPT module. You should set panels of 400W into the MC4 pole input, and another 100W worth of panels into the 7.9*0.9mm input. This measures would support 320-360W input power per hour in good sunlight conditions.
I have no idea what the "MPPT module" is. It says its included but I don't see anything other than the charging brick and the connector for the solar panels. Sounds like I can add a battery expansion which is a good thing. Any insight into this is appreciated.
