Capacity Concerns
wiseacre
North of the Adirondacks
I built an 8s battery on the workbench and ran a capacity test.
The battery is now fully discharged but I can't discern any difference in the weight.
I thought I'd be able to lift the new battery once it was empty
Is there anything short of dismantling and reassembling the battery in it's final placement that I can do?
It depends a lot on how many volts...
Well, I suspect amps weigh more than volts, 'cause a long time ago I owned a bass amp which weighed a ton.....
According to this diagram, Ohms is pretty heavy & strong.
Shortly, Ohm will be squeezing the shit outta Amp.
What will happen to Volt?
Volt will lose weight and get stronger (gain muscle mass) from all the extra exercise from trying to push amp? Or he'll just eat $hit? I don't know, I give up...
Maybe we gotta post this onto one of those unsolvable math problems websites and someone will figure it out.
