Hi,
I have a LiFePO4 4S 12V "100Ah".
One cell has much less capacity than the others. It has 70Ah while the others 90Ah. I'm fine with it but i was wondering if i could do something. I know that the best solution would be to buy another cell with more capacity.
My issue is that the weak cell always reaches 3.62v (that's my limits) much faster than the others. Also it discharge much faster than the others.
I'm not using often the battery and the weak cell always drops in voltage firstly. I want to do something to use all the capacity from other cells and store the battery much longer.
So, i was wondering if it is possible to wire both in series and parallel to keep them balanced constantly ?
Here is my 4S wiring and i drawn the parallel wiring.
Will it work ? What will happen if i put the 12V charger ? ?
Thanks.
Thanks.
